i have a 98 clio mk2, when i put it into gear it wont drive and when clutch is lifted it does not stall,, when i put it into gear it sounds like it goes in but makes a little noise as if its not in properly,, all forward and reverse gears dont work suddenly stopped half way through my journey any help please?
Most probably/could be the diff clip on the n/s driveshaft. Remove the shaft, after draining the gearbox oil. check the clip is in place if not replace, if it is in place then your troubles grow unfortunately....new gearbox time.....
i have had a look and the bolts holding the clutch plate in have snapped and part of the plate has broke does this mean it needs a new clutch?
