Hi, my Clio's (2006 MK3 Dynamique 1.4 5dr) locking mechanism has gone so the inside handle doesn't work and now I need to replace it. I'm looking online for a spare but these seem to specify between 3 and 5 door. Does anyone know if there's any difference between the locking motor for 3 and 5 door MK3s? It's the driver's offside one I need to replace.
If anyone has a picture of the part I need that would be a massive help. Cheers.
Lock will be the same for 3 or 5 door Clio but the link between the internal handle and lock will be different as 3's front door is longer.
Take off the door card and identify where the problem is, chances are the existing mechanism can be repaired with cable ties or similar especially if the lock works OK remotely and from the outside handle.
