hi guys ,clio 1.2 16v quickshift been running fine until recently then started to have trouble starting it was as if lazy fuel pump not pressuring up but if you turned ignition on and off twice car would generally fire up, now a symbol under the gear position indicator comes on intermittently looks like a gearbox when this is on the car is a little jerky and will die in reverse, if you stop and restart the car sometimes is perfect with no symbol other times just the same also symbol like steering wheel stays on for a few second sometimes i am leaning towards ecu or electrical connection fault any ideas greatly appreciated.
