1 - 8 of 8 Posts
Super mod..
We will need more info that you have given ..there are Mk 1/2/3/4/5 clio's..
Super mod..
Ok now to the door.. door will be held on by 2 hinges ..check strap and any wiring for say central locking and electric windows and speakers if fitted.. you will need at least another pair of hands and an impact driver to remove the hinge screws and check strap for the door B pillar.. check for wires between the front and rear door B pillar..would advise that you score around the hinges with say a sharp pointed object to make sure the hinges go back to the same place you removed them from.. if you feel you cant cope with any of this then it should take a body shop no longer that half an hour to do it so the cost should be reasonably low..if anyone has anything to add please chip in ..
Super mod..
hi phil no screws on hinges,nuts is it the same procedure,
Nuts will be easier than screws and thats a plus.. now you need a socket and bar or a ratchet.. and strong arms 馃挭
1 - 8 of 8 Posts
