Hi everyone,
My wife has a 2002 1.2 16v Clio which occassionally just refuses to start. I've replaced the coil/ht lead assembly but this hasn't helped.
The fault occurs whether the engine is hot or cold but most of the time it starts ok. When it decides not to start the only way to get it going is to very slightly depress the accelerator pedal while turning the engine over and then it starts ok.
Can anyone tell me where the TDC sensor is located so I can try cleaning it or replacing it.
If anyone has any suggestions I would be very grateful.
All the best.
Chris Brown.
Clio TDC sensor
Hi, Can anyone tell me where the TDC sensor ids on a 2002 1.216v clio.
I want to clean or replace it due to intermittent starting problems.
thanks,
Chris B
