Could be one of a hundred things but worth a check would be the crankshaft sensor. Easy to remove and clean to see if that makes any difference as a first attempt. Try starting with a search on this forum for "Clio crankshaft sensor". If that doesn't help, someone will be able to assist, although they might need more information about the problem.
