1 - 8 of 8 Posts
I have a clio II and have just upgraded from a tuner list to an update list. I have programmed in the update list cd player and it works, except that I can't use the steering wheel controls and the display doesn't work with it, yet when I connect my tuner list one back up, that works perfectly fine with the steering wheel controls. Does anyone know whether you can change a tuner list cd player for an update list one without any other cables? Any help would be greatly appreciated.
Hi kristopher
The upgrade should work with no wiring alterations,see link below:-
TLCDCEmu - Hardware
If you have a multimeter check for 12 volts on pin 5 of C1 this powers the display,C1 pin 2 the clock output will be a pulsing 5 volts.
hope this helps.
I am considering upgrading from the 'tuner list' to a 'update list'. Could you get your set-up working?
(Scenic II 2004 1.6)
Andre
Hi Andre,
Unfortunately we couldn't get it to work and sent it back to the seller who said he was 'selling it on behalf of a mate' and that it didnt work!:steam:
As yet we haven't tried another one! Sorry.
Kris
HI!
I have a megane II 2004 and I had a tuner list cd player. I have upgraded now to a mp3 update list player. I also have bought a dispay for this mp3 update list but I can not make it work. To connect the player to the dispay I have also bought the connector that feeds into the dispay. My main problem is that I do not know how to make the connections from wires that come from the player to the ones that go to the display. Do you guyes have any electrical schemes that I could use?
Thanks in advance!
1 - 8 of 8 Posts
