Having a problem with our 51 plate Clio.
Air conditioning running perfectly cool and heater working fine, but we keep finding damp patches in both front footwells with no sign of where any leak may be coming from. In addition, whenever we take a tight corner or a roundabout with the air-con on, we get fog pouring out of all the vents ! Any suggestions welcome please. Chris :confused:
Sounds like water has gained acces into the system - have you checked the pollen filter and the drainage holes at the air inlets. Is the drain pipe from the aircon blocked.
OK..thanks for that...don't know where to start looking though !
Regrettably it's many years since I used to spend Saturday
stripping an engine then rebuilding it before taking the girlfriend out !.......
Will the pollen filter or air-con drain be shown in the manual ? If not, where do I start (I learn quickly !)
Thanks,
Chris
