After reversing out of a carpark, I went to select 1st gear and it would not engage. It would not engage in any of the gears not even reverse which is the last gear i used! In fact i tell a lie! the only gear i could select was 5th and that is the bugger i had to use to limp home in (downhill 99% of my journey) can anyone tell me what has happened?
It is a "R" reg clio 1.9 diesel
Welcome to the forums Tet, I had the same kind of problem with my Lag, that was caused by a duff gearbox and dead clutch, hopefully its something more simple with yours, I would try and get the car to a small indepenent garage if you can as main dealer will be quite expensive, Good luck
clio gear nightmare
I have been under the car at my local ATS & disconected the linkage and tried to select the gears by hand but it still wont engage only in 5th! It goes int 5th no problem but there are no other gears I can sneak into............ and yes my sunroof leaks like niagra falls too.
