My driver's side door has just dropped about an inch and needs to be pushed up and in to close it. I looked at the top hinge and pin which seem solid and unmoving but there is movement as though the inside of the door is coming away from the hinge. Is this repairable or do I need a new door.
Check were the hinge is welded to the door - has it cracked. A weld repair may be possible. It is possibkle the hinge has seized causing the end panel to flex and crack.
