1 - 1 of 1 Posts
Hi...wonder if you could help me out here... I had a turbo fitted and since then i have the above codes. I cannot see a plug off anywhere. I have tried resetting the codes and they keep coming back. the car drives great but the engine light is on and its annoying. I bought a second hand egr valve of ebay and cleared codes but they are back again. am i barking up the wrong tree?. i have checked pins 1 and 5 and i have a 11.72 volts. also there is only 4 wires into the egr pin 1 (green) pin 5 (orange) pin 2 (white) and pin 4 (thinner green wire). thanks in advance : )
1 - 1 of 1 Posts
