I posted some time back about the noise behind my steering wheel and the white ribbon cable, which has now (as predicted) broken.
I have a quote of £220 to be repaired by ex-Renault techs in Dartford and so I thought, out of interest, I would email the local Renault dealer for a price.
To my surprise they questioned whether there was a second problem causing the steering lock not to function...
To clarify the symptoms...I had a loud/progressively louder scratching/coiling noise behind the steering wheel for 2/3 months which resulted in the airbag light, service light and the message "steering not locked" on the display.
Does anyone think is actually plausible or should everything function correctly after the switch replacement on Friday?but we also think that the
steering lock fault is being caused by a fault in the steering column lock, which is a separate part from the airbag rotary switch
