Hi All,
I've got an odd problem with my '97 trafic t1100 2.1 diesel. With the engine off I can select all gears fine, with the engine running and the clutch pressed down I can't move the gearlever to engage any gear, no graunching noise- the lever just wont move. If I put her in 1st. then press the clutch down and then start the engine I can pull away as normal, no dragging or slipping from the clutch.
Any ideas as to wether it's clutch or gearbox please?
Thanks.
Hi there, welcome to the forums.
Are you then able to engage the other gears if you start in first (with the clutch depressed)?
As a stab in the dark, I'm thinking along the lines of the idler gear.... (gearbox anyway, rather than clutch).
Anyone else care to advise?
Paul:)
Hi Guys,
Thank you, once you have pulled away you can change up, but it's hard to do. Adjusting the clutch had no effect.
