I have a J reg Espace 91/92 whilst it's cold it will start OK, but as soon as it gets hot it cuts out. I've changed the plugs and fuel filter, still the same. If I try and restart it turns ok but won't fire, I've notice if I take a plug out after trying to restart the plug is dry and not wet with petrol which you might expect if flooded. Can anybody help?
The first place I'd start is the coolant temperature sensor for the ECU.These have a habit of corroding and giving the ECU the wrong readings.
