Hello,
I have a T reg Scenic (the older model) and need a new radio. Does anybody know if a Philips radiosat 6000 is compatible or a philips 22dc278/62b,
thanks a lot,
Richard
Hi richardpeel
The philips radio sat 6000 will fit the iso connections without a problem.
The later model philips 22dc278/62b will need the display connector changed.
If you want plug and play go for the philips 6000.
Two more points worth a mention,if yours has the curved front you may need an adapter to fit it in the dash and get the code for the radio.
Hope this helps.
Thankyou for the welcome Ottoman and thankyou very much for the information Glenda that's all I needed to hear,
best wishes,
Richard
Hi richardpeel
Hope this helps.
Would anybody know where I can get the display connector from if I wish to get the PHILIPS 22DC278/62B model.
Sorry I really don't know anything about radio electrics etc.
best wishes,
Richard
Hi richardpeel
The connector you need for the 22dc27862b will be a square connector,take a look at this link :-
TLCDCEmu - Hardware
C1 being the one in question...i got mine from the local scrap dealer (any Scenic or Clio from 2000 onwards should have it).
The wire colours are the same.
ie. join colour to colour.
hope this helps.
