I have just noticed a slight sign of condisation in both my rear lights, i have a brand new megane is this a big problem should i go back to the dealer or will it sort its self out .
Thanks john:crazy:
Condensation is due to water leaking inside. It may go away in warmer weather only to return later. Moisture inside lights can play havoc with the bulb holder and its associated wiring so I suggest you have the problem investigated and sorted out.
