I have a2002 scenic 1.4 it overheats when i sit in traffic because the cooling fan does not cut in. if i connect the fan direct to the battery it operates ok. So i assume its the thermoststic switch that is broken. but i cannot find the switch or whatever controls it. please help
Hi, Did you manage to sort this or can anyone else help?
My fan isnt kicking in so overheats in traffic, the fan works, ive connected it directly to the battery and it spins fine.
I cant find the thermostatic switch anywhere to test.
Checked all the fuses.
Can anyone help?!
R
The sender unit is in the thermostat housing I believe that this controls the fan function? I've had a problem in the past with the fan not cutting out once the engine had warmed up and it was a faulty sender unit.
