I have a 3.0v6 sports tourer on a 51 plate and the cooling fan has stopped running, and the expansion bottle boils:steam! Does anyone have any easy checks i can carry out to find fault.
Let's be carefull out there
welcome to the forum Jamie. The sensor for the Rad fan is located on the radiator. Unplug the plug from it and bridge the 2 contacts on the plug (not sensor) with a piece of wire. The fan should then run. If it does the sensor is at fault, if not it is either the fuse for the fan or the fan itself that has failed.
