Hi all, I would like to ask the powers that be if they think a split charger would affect the battery isolator I have fitted to my ex ambo? Or will the cut out affect the charging system? Is it wirth trying one anyway? Your answer is much appreciated!:frown2:
back again
if the switch allows you to use both batts, do not do this, only switch off, or have on the starter batt setting, if on both batts setting it will partly use leisure batt to start van, and that will damage it in long run (but ok for emergency if starter flat)
as the split charge is wired straight from the one batt to other, cant see how the isolator would interfere with the charging when running as isolator comes after the split charge wiring
sorry only just seen your reply ignore most above
