Hello
All the coutesty lights work except the front passenger door light in the door card. i changed the bulb. When i open the door, the roof light doesn't come on either. every other door activates the lights when opened but not this one. I can only think that when the door is opened, whatever activates the light is failing. The car doesn't have a push switch button that opens when the door is opened.
Any advice welcome as this is a pain. Also have a leak in the passenger footwell but thats another story for another thread.
Hi there is a micro switch built into the lock in the door, they do fall from time to time i hope this helps Donald
Thanks for that Donald. Sounds costly? Do you know if they are easy to get hold of?
