Got A 2.2 Dci Master Cuts Out About 60 Mph In Fifth Gear Click The Key Back As Normal. Going Up Hill Same Thing At 40 Mph Had Injectors Checked High Pressure Pump,new Rail Sensor Fitted Wireing Checked At Renault Dealer No Fault Found Codeing As Rail Pressure Failure
Help !!!! Driving Me Mad
We have had a couple of Masters on the forum that have suffered the same problem,and both of them have been caused by injectors leaking back through the return pipes.
I'll try and find the threads and get back to you.:)
Heres one...(click on the link)
http://www.renaultforums.co.uk/engines/12151-renault-master-2-2-dci.html?highlight=master
It sounds like the system is contaminated with small particles of metal(from primary pump failure or dirty diesel) and this causes havoc with the high pressure pump and injectors.
There is another thread concerning a similar fault,but that one got so bad that in the end it refused to start.If you do a search for 'Master',you should be able to find it.:)
