After spending the last week trying to follow the instructions from the Haynes manual i now need some advice. I have removed the valve cover and unscrewed the manifolds from the head but cant get them to prise away. I also cant seem to be able to remove the timing belt from the end of the block/head, I can see bolts which i presume are the ones i need to undo but i cant find anyway fo fit a socket or spanner in the gap to get to them. It is an Energy engine and any advice would be greatly appreciated.
Thanks in advance
Thanks in advance
