Hi all. I am currently putting a new turbo on a 56 Meganne cabriolet 1.5 dci. After receiving the wrong turbo I have finally managed to get the right one. They are exactly the same to look at, however on the old unit there is a bracket that's bolted to it so u can adjust the wastegate. On the new unit there is no bracket so the wastegate bar moves all the way without any restriction. Do u know if the turbo should be bolted straight on or the bracket taken off the old unit and put on the new one? I thankyou for your help in advance
