Hi there,
I have an 03 clio billabong. And recently, i've been having a few problems.
1) When i brake, instead of the brakelights coming on, the hazards come on.
2) When I stick the signal on to go right or left, the signal comes on ok, as well as every single other light at the back, they all just start flashing on and off as if they were disco lights.
3) When I stick the signal on, and then brake, the indicator speeds up, but if i take my foot off the brake, it goes back to normal.
I've tried to clean the connectors and check the earths, but still having no luck.
Any help is much appreciated!
Thanks in advance.
sounds like the body computer which is located under the glove box, double check all ure earths again and even check the relays sometimes these cause the issue
Managed to sort it! Thanks for your help. Basically, we cleaned up the connectors, and that was having no effect, however, if you look into the black plug and see all the little connectors, then you will find that over time they can be pushed back so that there is a loose connection. If you get a pin, you can pull them out so that they will have the maxiumum connectivity.
If that makes sense!
