Door open light stays on even if all doors are closed, door courtesy light stopped working at same time, any ideas?
or ........if not door switch you may have water / moisture inside the ceiling light unit .
Al
Chances are one of the door switches is duff.
Which one ???
I maybe wasn't, clear on the problem I have it's the dash warning light that is showing door open when they are all firmly closed I then get an audible warning similar to handbrake on the it leaves a message on the dash which says Door Open this stays on for the duration,HELP
what @Dancingdad meant, I am pretty sure, is which door is the car saying is still open? the door that is showing as still open may have duff switch in it, or it could be as @A55ii said, water in your courtesy light, if you have a sunroof
