1 - 8 of 8 Posts
Has anyone got any information on the removal of drivers door trim on a Laguna2. Some kind person bumped mine whilst I was attending a funeral leaving the door panel stoved in and scrapes along the side and gouged front door trim. If the door trim comes off easily, it may well push out just needing a respray and new outside trim. any information will be welcomed . Thanks DEZ
Many thanks for responding
Hi Guys
Many thanks for taking the trouble to respond. Just to get things clear, it is likely that the interior door trim will have to be removed to push the "bump" out. As the exterior trim, the plastic with the side repeater in it, is mangled, it will have to be removed to fit a replacement after spraying. the panel.
Thanks again All, Dez
There are quite a few useful posts on dent repair in the forums if you do a search under Dent repair or Scratch repair.
Ottoman
Not being funny but you might just find a same colour door on Fleabay - could work out cheaper. Just search 'Laguna breaking'
1 - 8 of 8 Posts
