I have a laguna II sports tourer.
The problem is:
1: Lock the doors using the keyfob twice for deadlock
2: All the door lock, check the exterior handles and they are all locked.
3: Come back after a period of time and you can open the drivers door (activates alarm). All other doors are still locked.
Anyone have any idea's why or how to cure the problem?
Yep having similar problem, rear off-side door will not lock when deadlock applied, have found if I use single press all doors lock fine, alarm is armed etc.
If I use the Child lock for the rear it will lock all doors inc deadlock.
Couple of things to look at;
1. Door lock mechanism, this can be purcahsed 2nd hand for around £40.00 simple enough to fit.
2. Check Wiring loom for any frayed wires & connectors to main system for any signs of bent/dirty pins etc, use WD40 to clean.
We've not tried no 1 byet, will let you know
