Hi all,
please could someone help me. I am a key worker and can need to return to work. My is Grand scenic dynamique nav dci 2016. It needs a new DPF pressure sensor fitting, it was booked in to the garage but sadly they have closed. I have bought the part and have removed various cosmetics above the bulkhead trying to locate it but to no avail. Does anyone know where it is located so I can get it back on the road please.
Not a 100% sure on your motor of exact position but will be fairly close to the exhaust pipe, by the DPF.
Look for a box towards the engine end of the pipe that has two rubber pipes, one at either end.... the other end of those pipes is the sensor.
Common that sensor fail diagnosis is actually a blocked or split pipe to the sensor, try cleaning them first.
Check google for mobile mechanics in your area, as a key worker you may be surprised at the help you may get... hopefully.
