In the middle of removing the gear box to enable me to change the clutch, after the thrust bearing is no more. Have split the gearbox from engine and removed the passenger side drive shaft but can't completely remove the gearbox to access the clutch. I believe this maybe due to the drivers side drive shaft but have no idea how to remove it. Any ideas how to remove it or is there some else I have missed?
