Hi All - just some help and advice iff possible
I have a central locking issue - all doors lock apart from the drivers side when using the fob key - it does click but does not seem to lock any ideas - or even better are there any decent renualt specilasits (Not main dealer please) in Brum.
many thanks
Hi newren
Welcome to the forum.
As the drivers door clicks when the central locking is used i would not suspect the problem to be wiring or fuse, but the solenoid itself maybe loose, to check this the door panel inside will need to come off.
Not sure about the Renault specialist in Brum sorry (I'm from Kent) will leave for another member to advise.
Hope this helps.
renault garage birmingham
Hi All,
need help need some work doing on my scenic - heater has stopped working and drivers door wont lock are there any decent garages in the brum area.
