Espace 2L RXE 1994 manual. driverside door wont open or lock. it's been happening more and more often recently. i have to try several times before it open or locks.
Hi what i would do is take the door panel off so you can have a look to see what is happening when it does lock and whats happening when it does not lock i would put it down to two things its either the locking mechanism or the unit which triggers the lock ie the central locking a spray of the old WD 40 on some parts might just be what it needs to loosen things up i hope this helps all the best Donald
get another solenoid/motor from a scrap yard.
