Discussion Starter · #1 · (Edited)
Coherence between camshaft sensor and engine speed.
I have had both the engine sensor and camshaft sensor rewired and replaced. Also a new cambelt has been fitted along with the tensioners.
The problem with the car is that it keeps cutting out when the reves drop. if I sit at trffic lights on tick over it will stall. when I accelorate after starting the engine it will stall. when slowing down to stop it will stall.
