whats the uch is that the card readerOnly if you also get the UCH, you will also need the V5 or at least the green slip or you not be able to buy a replacement key in the future should you need one.
Wouldn't he also need the imobiliser as well?Only if you also get the UCH, you will also need the V5 or at least the green slip or you not be able to buy a replacement key in the future should you need one.
