Discussion Starter · #3 ·
oil spilt on topping up got into the 1st coil plug.did not know till limp warning came up.changed coil plug limp warning still there so got reset ecu.is it possible without connecting to computer
Welcome to the forum.:)
*Sometimes* the light will go off on it's own once it's happy that the engine isn't miss firing any more,but usually if the light stays on then there is still a fault present.
Any decent independant garage with a sensible scanner/code reader can access the fault codes and clear the memory on the ECU so either way there is no need for an expensive dealer visit.
