We have a 2004 scenic, which has developed a failure with the driver side electric window - it wont operate.
When you press the switch up or down you can hear an initial noise as if the motor was starting to work, but then nothing and the window does not move at all.
Do we need a new window motor - or does the fact that you can initially hear a movement mean it is another problem?
Any advice much appreciated.
