how do I test if it's motor, regulator or switch my window is stuck open
W woody33 · Registered Joined Mar 24, 2011 · 1 Posts Discussion Starter • #1 • Mar 24, 2011 how do I test if it's motor, regulator or switch my window is stuck open
W wozere · Registered Joined Mar 10, 2011 · 7 Posts #2 • Mar 27, 2011 Please let me know if uoy get a solution as I have the same problem
C Colcut · Registered Joined Dec 29, 2010 · 62 Posts #3 • Mar 28, 2011 What ever you do, do not take it to Renault unless you can confirm it's the regulator! I think you need to get someone with a CAN CLIP device to read the body ecu, or use a multimeter to find the fault manually If you just want the window put up then just go to some independent place - Renault will charge £100 just to do that!
R Recycled Scenic · Guest Joined Jan 1, 1970 · 0 Posts #4 • Mar 28, 2011 woody33 said: how do I test if it's motor, regulator or switch my window is stuck open Click to expand... wozere said: Please let me know if uoy get a solution as I have the same problem Click to expand... What year and model is it?
M mitchy · Registered Joined Feb 23, 2009 · 10 Posts #5 • Apr 9, 2011 i have same problem called green flag out could not even get panel of to look had to take to garage find out monday problem
