I replaced the electric window mechanism on the front drivers side of my 2001 Renault scenic. It worked fine for 2 weeks then suddenly the window kept opening by itself like someone had pressed the button to open the window.
It must be a fault with the electrics, is there a way I can check this? At the moment I had to disconnect the cables to the electric window regulator as it kept opening.
I can still occasionally hear a 'click' like someone is pressing the button to open the window. Maybe something is broken in the switch, or moisture has got in and is making it happen.
Is it easy to take the switch out and take it apart.
Any advice or links showing how to do this will be appreciated.
Try reconnecting regulator and disconnecting back of switch to see if this stops it happening. if so replace switch.
