newbie , the passenger door window has dropped down ,it seems to have come off its roller .how easy is this to fix ?does the inside panel remove easily?
Help please!!!!
Hi Benson and welcome to the forum, I'm sure someone will be along to help soon..There are obviously ways of removing the door card/trim to allow access to the guts of the window mechanism, someone else may know what screws/clips to remove.
Hello, mine did the same last year. The window mechanism broke, took the door trim off, and then propped it up with a piece of 2x4 wood. Dealer fixed it under warranty. It describes how to remove the door trim in a Haynes manual, regards Damian.
