hi My passenger window will not move, i have tried to remove the door panel for a better look but with no sucess can anyone tell me how to remove the door panel
cheers smigs
Hi iam not sure but there will be screws around the door handle panel and in other places you may note see them because they are coved with little caps that can be pulled out i think if not they will be about but just placed that they are hard to see. Once you do that be very carfull when pulling the panel off just go easy and it will pop off and if you have electrics going to the door once the panel is off you will need to unplug them from inside the panel to let you take it away from the door area i hope this helps
