Just replaced the battery on my Scenic 2 and everything works OK except the electric windows.
Each time you press the button it goes down about 1 inch only then stops. To fully open the window takes about 15 clicks. Same on the way back up.
Any ideas? Could it be some fuse blown or is there something I need to reset? :confused:
Someone said on my thread to hold the button up for 10 seconds or so and then try it.
Beyond that I'm no help. But if it stays down and wont go back up, about 15mins on jiggling the button will eventually make it go back up. I found that out.
Hello,
you need to reset the electric windows. To do this do the following.
1) Take window right down and hold button down for about 10 seconds.
2) take window up and hold button up for about 10 seconds.
3) Window should now be reset and go up and down in one smooth fluid motion. Repeat same on other window's.
Harry.
