This is a grim tale. Basically my 1.4 mk1 failed on emissions. I'm pretty sure the garage destroyed the engine. Rather than scrapping it I decided to get a replacement engine, and also needed a new exhaust. My mechanic has fitted everything and again it has failed on lambda too high after 2nd fast idle. My mechanic says the engine is no good, thinks its burning oil. the guy I bought the engine off says it will be an air leak or fuel problem as the engine is sound. I'm about 1k down and no further forward, any advice would be greatly appreciated.
Thanks,
Tony
Thanks,
Tony
