Does any one have any information on the engine compartment fuses - the ones with the heavy duty fuses (70A etc,).
The diagram in the Haynes manual say they are numbered from something like 52 on. My fuse box numbering is 1 to 12 from the front and has no. 5 missing.
I don't want to start pulling them to see what stops in case I finish up having to get something re-coded by Renault.:(
Any ideas on which fuse controls what and what the correct rating should be?
Thanks.
Engine Bay Fusebox
Hi madnoel, Yes, First place I looked. Then tried the handbook. Next was the fuseholders to see if there was any clue there.
Of course by this time I was getting a bit frustrated:steam: as there was no label on the inner wing, nor on the underside of the bonnett or even on the information plate by the slam panel.
Keep an eye on the newspapers......"Man, Believed not to be Torquay Hotelier, Beats Renault Laguna to death in frustration".:rofl:
