1 - 1 of 1 Posts
hi all
been on her before with espace 2.2dci pwer loss probs , reanult replaced EGR valve , EGR inlet pipe ( The steel one ) , turbo sensor and turbo which cured the fault for a month or so . car pulled like a train .
Now however it just dies on acceleration , no warning lights , no alarm , no creep mode , however as with before recycling the ignition clears the fault until the next time . ive taken it down the road in 2nd at max revs which is fine until i then get into top gear and it dies instantly , if i drive it like a pussy cat i can just about get away with it ut have had a few irate drivers behind when pulling away from a junction roundabout !
am at end of tether and wife hates it now as well ! :crazy:
1 - 1 of 1 Posts
