As a matter of course, and it being an easy job to do one afternoon in went in search of all the earthing straps to remove, check condition, clean up and refit. on doing so I found the battery earth ring terminal to the car body to be almost ripped through, literally hanging on by less than a quarter of the brass terminal, therefore a possible fail for the future now rectified.
Now of the flat braid type earth straps, on mine I noticed the green corrosion, so what I do, is clean off the corrosion and cover the things in vaseline, sure, it picks up road filth, but at least it's not corroding.
