Recently my 1.9dCi Lag II has started to emit what I can only descirbe as a howl under part load and full throttle conditions, is this a common problem?? I had a quick look for any split boost hoses but nothing obvious, no black smoke either. Also the temp gauge acts eratically so I purchased a temp sender from Euro (3 wire) but was unable to locate it on the engine any ideas anyone??
If its not one thing its another, the joys of renault ownership!!
As Chris says,the turbos on the dCi's are suspect,and also intercoolers can split giving similar problems.I'd get it checked asap just to be on the safe side.:).
