Heya
Currently have a Renault Megane 53 1.6 petrol and the engine management light has been on for some time. Not being a fan of taking the car into the garage, I have purchased an OBD scanner and the car has produced the following codes.
P0141 - Sensor Heater Circuit Bank 1 Sensor 2
P0010 - A Camshaft Position Actuator Circuit / Open Bank 1
The car runs okay, however on first starting when cold, there is a very strong petrol smell (similar to an old petrol car with the choke out) and sometimes struggles to not stall without keeping the revs on.
Also noted a significantly higher fuel consumption and possibly a small loss in power when warm.
I have looked up the codes and the following have been suggested
P0141 - Replace oxygen sensor
Any guidance would be greatly appreciated as I have been ripped off many times by garages who have replaced the wrong parts etc etc.
P0010 - Haven't had much luck with this other than it may be something to do with the VVT electrical system, maybe the solenoid or camshaft sensor.
Just looking for some guidance as to what maybe the problem. Not a fan of taking to garages as they seem to replace parts that don't need replacingetc and costs go up.
Possibly a couple of sensors malfunctioning and whether I need to replace them.
Adam
Adam
