ive had the head gasket replaced on my p reg megane after a thermostat failure and the engine runs ok but makes a clicking/tapping moise when accelerating. it revs fine and when speed is kept constant there is no noise at all in fact its very smooth but i get a noise when i open the throttle but not through entire rev range. ive had a listen with bonnet up and cant determine where its coming from.
anyone on here got any ideas?
hi, thanks for the response.
well i thought that but if this was the case then the noise would be constant and evident all through the rev range,
which it isn't.
so still a mystery
