1 - 16 of 16 Posts
Banned
Topping car antifreeze up the other day on a 1.2 clio and decided to check oil etc when I lifted off the oil filler cap I noticed a little bit of white moisture not as thin as water slightly thicker on the housing of the cap and around the edge any ideas? Thanks
Sexy at 70 super duper mod..
Its common to the 1.2 D4F engines..when did you last have an oil change..good hard italian tune up can help if you do lots of city driving..
What he said...commonly known as Mayonaise.
It's water/oil emulsion and fairly typical of short journey engines when the weather gets colder and damp.
Nothing to worry on unless accompanied by loss of coolant and or increase in oil levels.
Banned
Had a service done when I purchased the car start of July it was this year I do a lot of city driving and the odd day 20+ mile journey but normally just city driving
Banned
I’ve had to top the coolant up the other day but it’s been that way for a while and as far as I’m aware there’s no gain in oil lever maybe if anything a little loss
Sounds typical of most engines at the start of winter. Shouldn't be anything to worry about unless there are more serious issues present at the same time ... but as you havn't mentioned then assume its all ok.
What also doesn't help is in the rocker cover there is a PVC and they also get clogged up..see this thread..
Banned
Discussion Starter #10
May seem like a daft question what happens if the pvc gets clogged or blocked
Crank case breather hose looks like this..
Take your airbox off and have a look down the back of the engine..
Banned
Discussion Starter #14
No problem I’ll have a look tomorrow thanks for the advice I appreciate it
1 - 16 of 16 Posts
