1 - 1 of 1 Posts
HI there, , I have a problem. My wifes 2002 Clio 2 1.4 Auto also has what seems like a fuel surge problem at 3000rpm but only in 3rd gear, if you put your foot down (esp on uphill) it seems to hicup take a while to change down a gear and then it revs clear until it goes into 3rd again. We have had a problem with the alternator siezing (repaired it) the belt jumped off and had to be replaced. the timing belt was replaced at the same time as a precaution. Car has done 50000miles. any suggestions will be most welcome.
On the alternator belt I have dropped 3 belts in 6 weeks, Renault workshop tells me the alternator pulley is not in line, this is not correct unless the pulleys are not meant to be actually in line, any confirmation/comment would be appreciated
1 - 1 of 1 Posts
