Status
Not open for further replies.
hi i have a 1.2 16 valve clio.It had a misfire then went on to 3 cylinders.Took it to garage and found the tamper box had rubbed wires.I changed loom went back on to 4 cylinders but when you set off, go in revers,hill start or as i have noticed to day on tick over it still misfires.But on normal driving it seem ok.Can any 1 help...Thanks..Geoff
Just a polite reply to ask you to please refrain from starting new threads concerning the same problem,there are answers to your original thread which you may like to read.
I have removed the other two threads you started,this one will dissapear later on this evening too.
Many thanks.:)
Status
